Vista 5.0.3 Graphics Editor crashes when you right-click on a graphics page in Workstation and click edit.
  • Vista 5.0.3 Graphics Editor crashes when you right-click on a graphics page in Workstation and click edit.
‎2018-09-07 03:03 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:23 AM
Here is the error message:
Could not load file or assembly 'TAC.Interop.TacosOI, Version=5.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
FileLoadException
at TAC.Graphics.Windows.Vista.VistaSystemProxy.Create(String server, String user)
at TAC.Graphics.Editor.EditorApplication.CreateApplicationForm(ReadOnlyCollection`1 commandLine) in C:\TAC\VistaSw\V5030\Graphics\Editor\EditorApplication.cs:line 90
at TAC.Graphics.Editor.SingleInstanceApplication.<>c__DisplayClass3.b__1(Object splashFormSender, EventArgs splashFormEventArgs) in C:\TAC\VistaSw\V5030\Graphics\Editor\SingleInstanceApplication.cs:line 79
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
Vista Workstation 5.0.3
TAC TGML Graphics Editor 1.0.3
An error occurred at installation and the Graphics Editor must be removed completely and reinstalled.
  1. Shutdown the Vista Server and Workstation.
  2. Uninstall the TAC Graphics Editor 1.0.3 from the Control Panel of the PC.
  3. Delete the entire C:\Program Files\TAC\GraphicsEditor directory that is left behind from the un-install.
  4. Download the TACGraphicsEditor103.exe from The Exchange.
  5. Re-install the TACGraphicsEditor103.exe
  • 3030
