Vista 4.2.0 in Higher Resolution Monitors
  • Vista 4.2.0 in Higher Resolution Monitors
  • SESA116857
    SESA116857
‎2018-09-06 03:11 PM
TAC Vista Workstation 4.2.0
Vista 4.2.0 recommends a screen resolution of 1024x768, but the program will work with higher resolutions.
The font size is not configurable in Vista. As the resolution of the monitor increases, the text will look smaller and smaller on the screen.
While the size of the font is not selectable the font can be chosen from a predefined list of fonts which may contain a more visible option at higher resolutions compared to the default.
  • 1763
