VisiSat 2.1 project upgrade program
  • VisiSat 2.1 project upgrade program
  • Gary
    Gary
‎2018-09-06 03:03 PM
VisiSat 2.1
The VisiSat 2.1 upgrade program supplied with VisiSat 2.0 and 2.1, is to upgrade projects originally created in VisiSat 1.1 or 1.2 to the VisiSat 2.* format. VisiSat version 1.* stored all project information under the main project folder. VisiSat 2.* stores all project information and controller configurations under a folder "VisiSat" under the project folder.
Projects must be upgraded and import if originally created in VisiSat 1.*. DO NOT just copy VisiSat 1.* files into a folder named VisiSat under your project folder, then run it in VisiSat 2.*. You will experience problems with your project if this is done.
Note: The way VisiSat 2.* stores and accesses the point information is completely different to VisiSat 1.*.
  • Satchwell MicroNet
  • 2164
