Virtual memory setting on a Continuum Workstation PC
  • Virtual memory setting on a Continuum Workstation PC
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:26 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-06-05 01:15 PM
Question on what to set the virtual memory to on a Continuum Workstation PC
Andover Continuum
Windows XP
Virtual Memory Requirements
The virtual memory "Initial size (MB)" setting on your workstation PC should be set to a minimum of 1 GB. To make this change:
  1. Go to Start, Settings, Control Panel.
  2. In the Control Panel, double click System. The System Properties menu, shown on the next page, appears.
  3. Click the Advanced tab and click Settings in the Performance box. The Performance Options menu appears.
  4. Click the Advanced tab. In the Virtual Memory box, click on Change. When the Virtual Memory dialog appears, fill in the desired paging file memory size (initial and Maximum).
  5. Click OK as you back out of the dialogs.
  • 3977
