Virtual environments supported for use with Security Expert
  • Virtual environments supported for use with Security Expert
‎2018-09-10 09:42 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:23 AM
What virtual environments are supported for use with Security Expert?
Security Expert
  • Security Expert
  • Microsoft SQL Server
Which specific virtualization software has been qualified to work with Security Expert?
No specific virtualization software has been qualified with Security Expert. The Security Expert Compatibility Matrix describes support for Virtual Environments as the following.
The Security Expert server is supported on Virtual Server Environments. However, Schneider Electric reserves the right to request customer replication of any errors in a non-virtual environment.
When installing under virtual server environments special care must be taken to ensure that the system requirements are met by the virtualized hardware. The VM must be carefully reviewed with regard to resource and performance before completing any installation.
  • EcoStruxure Security Expert
Tags (12)
  • 19381
  • AdamSteele20
  • AdamSteele21
  • AdamSteele23
  • AdamSteele25
  • citrix
  • CraigEllis22
  • HernanUruena24
  • hyper-v
  • QC_181
  • vmware
  • xenserver
