Virtual License for Sigma 4.08 – License Server 'Unable to connect to "Server"
  • Virtual License for Sigma 4.08 – License Server 'Unable to connect to "Server"
  • CraigEl
    CraigEl
  • Gary
    Gary
Gary Schneider Alumni (Retired)
‎2023-04-28 07:24 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-09 04:02 PM
When installing Sigma 4.08 using a software license, the following error appears in the License Administrator after entering the Entitlement ID:
“Unable to connect to 'Server'”
  • Satchwell Sigma
  • Building Operation License administrator
The License Administrator requires an active internet connection to communicate with Schneider Electric’s online licensing server when validating or activating an Entitlement ID.
If the PC is offline, the License Administrator cannot reach the server, resulting in the error.
If internet access is not available, use the Offline Activation Tool to activate the license manually:
🔧 Offline Activation Process
  1. Download the Offline Activation Tool
    Offline activation Tool
  2. Generate a Request File
    • Open License Administrator
    • Enter the Entitlement ID
    • Choose Offline Activation
    • Save the generated request file
  3. Transfer the Request File
    • Move the file to a PC with internet access
  4. Upload to Licensing Portal
    • Go to the Schneider Electric Licensing Portal
    • Upload the request file
    • Download the response file
  5. Activate License
    • Transfer the response file back to the original PC
    • Load it into License Administrator to complete activation
Labels (2)
  • Satchwell BAS & Sigma
Tags (2)
  • CraigEllis25
  • GaryMontague23
