View the routing table and delete entries on a host that is part of a network using TCP/IP
  • View the routing table and delete entries on a host that is part of a network using TCP/IP
‎2018-09-06 03:26 PM
How can I view the routing table on a host that is part of a network using TCP/IP?
How can I remove entries in the host's routing table?
  • I/NET Host
  • IP Network
Troubleshooting IP communication often involves viewing the current routing tables at a host station. This will help determine if they need to be cleared.
View the Host Routing Tables
  1. Go to Start > Run > and type "cmd" to open a DOS screen
  2. Type "route print" and hit Enter
Delete an entry from the Host Routing Tables
Example to delete address 157.0.0.0:
  2. Type the following: route delete 157.0.0.0 and hit Enter
  3. Type "route print" and hit Enter. This address should not appear.
  • TAC INET
Tags (3)
  • 1105
  • command
  • prompt
