View the Personnel Object Picture and the Video of the person entering the area on the same PinPoint Graphic
  • View the Personnel Object Picture and the Video of the person entering the area on the same PinPoint Graphic
  • sesa116827
    sesa116827
‎2018-09-06 02:57 PM
How to configure a PinPoint Graphic to show both the Personnel Object Picture and the Video of the person entering the area.
PinPoint Graphic
A dual view of the person's credentials as well as a live feed of them entering the area is a good view for security personnel.
Assuming the personnel and door objects and the pinpoint Graphic were created, also create:
  1. Create A Video Server
    • From the root click new Video server, add the ip address of the Video Server and account info.
  2. Create A Video Layout From the root click on new Video layout.
  3. Edit the door in the selected area and open the alarm tab. Add Root\Door access and click enable.
    • In the graphic box add the assigned graphic.
    • In the Video Box add the Video Layout object.
  4. Edit the Door access Notification Actions. Add desired actions. Display Video, Display Graphic.
  5. Open Pinpoint Graphic.Insert Active component
    • Personnel Picture
    • Assign attribute LastPersonentrd
  • 2665
