Variable is a zomby
  • Variable is a zomby
  • David_Purser
    David_Purser
Variable is a zomby
Picard David_Purser Picard
‎2023-05-03 10:58 AM
on ‎2023-05-03 10:58 AM
The following record is seen in trace logs of EBO servers that have a BACnet Interface:
nsp.pin.BACnet.VariableProperty PollingVariableProperty: variable is a zomby!!
  • Building Operation Automation Server
  • Building Operation Edge Server
A zomby variable is the BACnet plugin coming across an object that will be deleted but has not yet.
No further action is required.
  • DavidPurser23
