Valves to be used in system with 28% bio-ethanol.
  • Valves to be used in system with 28% bio-ethanol.
  • SESA150559
    SESA150559
‎2018-09-06 09:50 AM
Are the V211T, V222, V292 valves suitable in a system containing 28% bio ethanol?
  • V211T
  • V222
  • V292
Application requirement on content.
With a content of only 28%, the valves should work just fine. Cast iron is not ideal, but it works fine. Stem packing materials are EPDM and teflon, and they will also work fine with this content.
  • Field Devices
  • 15089
100% helpful (1/1)
