Valve mounting position in pipe work
  • Valve mounting position in pipe work
  • SESA150559
    SESA150559
‎2018-09-06 09:55 AM
Is it possible to mount a valve in any direction in a pipe work?
general Valves
general actuators
Mounting a valve/actuator in the incorrect position may cause damage to actuator.
The positioning options of the valve are based on the recommendations on how to mount the actuator. Please see the actuator data sheet for recommendations.
  • Field Devices
  • 14827
