Valve Flange Tables
  • Valve Flange Tables
  • DavidChild
    DavidChild
Valve Flange Tables
‎2018-09-06 12:25 PM
Last Updated: Sisko DavidChild Sisko ‎2019-08-20 02:36 AM
Valve Flange Tables
Field Devices
  • Valves
  • Flanged
  • Gaskets
  • Bolt holes
  • PN rating
  • PCD
What flanged tables are used with what valves?
The PN of the valve and the valve size will indicate the diameter, PCD (Pitch Circle Diameter), number of bolt hole/size and bolt size and therefore size of flange and gasket.
Download the flange tables for BS EN 1092 (metric), ANSI  (ASA) and BS10 or here for an alternative flange table document.
  • Field Devices
Tags (2)
  • 8298
  • DavidChild19
100% helpful (1/1)
