Values named Temp_FBValue in StruxureWare Building Operation
  • Values named Temp_FBValue in StruxureWare Building Operation
  • sesa139513
    sesa139513
‎2018-09-10 05:08 AM
What are the values named Temp_FBValue
StruxureWare Building Operation Site with Function Block
Site is wondering about the values named Temp_FBValue. What is the meaning and why you cannot bind them.
A function block variable with the name XXX_FBValue is an output variable from an Input block (e.g. RI- BI- II- PI- block). It’s an internal variable and ought to be hidden, but it’s not so today.
It should not be possible to bind theses variables.
  • 6868
