VZ308 ports
  • VZ308 ports
  • SESA150559
    SESA150559
VZ308 ports
‎2018-09-06 12:50 PM
Defining flow direction in VZ308 valve.
VZ308
Flow direction definition in mixing application.
As described in the data sheet:
The valves should be installed as mixing valves,
with ports connected as:
Port AB: Combined flow outlet
Port A: Controlled flow inlet
Port B: Bypass inlet
  • Field Devices
  • 7040
