VZ22/32/42 compression connection types
  • VZ22/32/42 compression connection types
  • SESA150559
    SESA150559
‎2018-09-06 09:52 AM
In some applications, a compression/conex type connection is requested or required.
VZ22
VZ32
VZ42
Application requirement.
Unfortunately, no such connection is available through Schneider Electric, and must be provided from external source if required.
  • Field Devices
  • 15022
