VT-1 I/O Module issuing result codes prematurely
  • VT-1 I/O Module issuing result codes prematurely
‎2018-09-07 04:33 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:22 AM
VTState value displays 204 before the phone is answered.
When a message is played the VTState goes directly to 301 when it should wait until the message has completed.
  • I/O Module
  • Continuum CyberStation
  • CX9900
  • CX9680
The cause of the problem is unknown, but flashing the firmware will typically resolve the issue.
  1. Flash upgrade VT-1 IO to most recent firmware.
  2. If the most current firmware is already installed, reflash the unit with the same version firmware.
Buildings Business Extranet Software
  • 4408
