V321 (DN65 to DN100), M800, M1500, MV15B, M3000
  • V321 (DN65 to DN100), M800, M1500, MV15B, M3000
  • DavidChild
    DavidChild
‎2018-09-06 01:06 PM
The Forta range actuator does not fit onto the V321 Valve.
V321
M800
M1500
MV15B
M3000
The actuator has a 10mm fitting, the valve (DN65 to DN100 only) spindle has a 8mm stem.
On V321 valves size DN65 to DN100 an adaptor piece is supplied with the valve part no. 880-0133-000 to adapt the valve spindle to the actuator drive.
The part no. 880-0133-000 can be ordered separately.
  • Field Devices
  • 6553
This is a heading
