Using the Xenta 511, will value pages only show temperatures in Celsius? How do you get them to display in Fahrenheit?
  • Using the Xenta 511, will value pages only show temperatures in Celsius? How do you get them to display in Fahrenheit?
‎2018-09-06 03:25 PM
XBuilder
Regional settings can be project wide or per point.
When creating a new TAC Xenta 511 project, select to use US values. You can also select conversions to occur per object.
  • 1131
