Using Zigbee VingCard Network and Zigbee Standard Security Network on the Same RP-C
  • Using Zigbee VingCard Network and Zigbee Standard Security Network on the Same RP-C
  • MikaelKrantz
    MikaelKrantz
Kirk MikaelKrantz Kirk
‎2025-10-23 06:44 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-23 05:48 PM
You need to integrate both:
  • VingCard lock
  • MTH-G-5045 / WDC-G-5045 window and presence contacts
…into a Zigbee network on the same RP-C (Room Controller) device.
EcoStruxure Building Operation.
  • Building Operation Room Controller (RPC) 24 V.
  • Zigbee
When performing device discovery:
  • If using Zigbee VingCard Network, the MTH-G-5045 / WDC-G-5045 devices are not found.
  • If using Zigbee Standard Security Network, the MTH-G-5045 / WDC-G-5045 devices are found.
This occurs because the two Zigbee networks are fundamentally different in protocol and device compatibility.
It is not possible to use both Zigbee VingCard Network and Zigbee Standard Security Network simultaneously on the same RP-C device.
You must choose one Zigbee network type per RP-C:
  • If you need VingCard lock integration, use Zigbee VingCard Network.
  • If you need MTH-G-5045 / WDC-G-5045 integration, use Zigbee Standard Security Network.
⚠️ Important: These networks are mutually exclusive on a single RP-C. Consider deploying separate RP-C devices if both network types are required in the same installation.
Labels (2)
  • Field Devices
  • MikaelKrantz25
