Using Russian language with I/NET
  • Using Russian language with I/NET
  • sesa150561
    sesa150561
‎2018-09-06 02:34 PM
I/NET foreign language translations
I/NET (with SQL) that is installed on an English operating system will not be able to display Russian alphabet characters if regional settings are later changed to Russian.
To avoid this problem, change the regional settings before the installation I/NET and SQL.
  • TAC INET
Tags (2)
  • 3614
  • letters
