Using MP-C Display to create temporary IO Points
  • Using MP-C Display to create temporary IO Points
  • JohnBoehmer
    JohnBoehmer
  • AbeMeran
    AbeMeran
JohnBoehmer Schneider Alumni (Retired)
‎2019-08-21 07:56 AM
Is it possible to command the outputs on an MP-C controller before it has been commissioned in EBO?
Building Operation Multi-purpose Controller
It is necessary to verify the field device wiring and control prior to the MP-C controller being brought online.
The following video demonstrates how temporary outputs can be created and controlled in an MP-C controller without the use of a front end system.
Tags (6)
  • AbeMeran20
  • commissioning
  • jboehmer2019
  • JohnBoehmer19
  • mp-c
  • MP-C Display
100% helpful (1/1)
