Using I/NET2000, Can a site change a filemaster setting?
  • Using I/NET2000, Can a site change a filemaster setting?
‎2018-09-06 11:50 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:22 AM
I/NET2000
Using I/NET2000, can a site change a filemaster setting?
Not, without difficulty. Setting a pc as a filemaster makes irreversible changes in software. We, in tech support have not found a way to reverse them, short of uninstalling Inet, deleting the root directory, and removing registry entries. Then reload Inet software. See pages 1-12 through 1-14 of TCON 237, Technical Reference Guide for a discussion of filemaster functioning.
  • TAC INET
  • 1283
