Using HyperTerminal to dump/reload controller with terminal interface.
  • Using HyperTerminal to dump/reload controller with terminal interface.
‎2018-09-06 01:29 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:22 AM
Dumping or reloading a NetController using HyperTerminal.
Windows HyperTerminal
CX9900
CX9400
CX9200
Command Terminal Configuration Guide
Infinity and Continuum Window Interface
Not known cause.
Click here for instructions on using HyperTerminal to dump or reload controller.
 For full details on using the Window interface as used on Infinity and 1st Generation Continuum controllers, you can download the Command Terminal Reference Guide.
  • 6057
