Using AC-1A door modules in a Continuum Transition to Security Expert
  • Using AC-1A door modules in a Continuum Transition to Security Expert
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2025-07-27 11:47 PM
on ‎2025-07-27 11:47 PM
Clarification needed on whether AC-1A door modules are supported in Security Expert.
EcoStruxure Security Expert
  • SP-AC1 Controller
  • Andover Continuum door modules:
    • AC-1
    • AC-1 Plus
    • AC-1A
The AC-1A door module is not explicitly listed in the Continuum Transition documentation, leading to uncertainty about its compatibility.
Although the AC-1A door module is not specifically mentioned in the documentation, it is supported by the Continuum Transition Tool.
This means it can be used with Security Expert when transitioning from a Continuum system.
For detailed transition steps, refer to the Continuum Transition documentation available on the Schneider Electric Exchange portal.
  • EcoStruxure Security Expert
  • AdamSteele25
