Using 24V as control signal on MD20
  • Using 24V as control signal on MD20
  • SESA150559
    SESA150559
‎2018-09-06 12:10 PM
Is it possible to use a 24V signal to keep the actuator in a constant position?
MD20
MD-20
In some applications, a constant signal is requested for use as a safety device (spring return) only.
The MD20 is designed to use a 2-10V control signal. Anything outside of this spec is not recommended.
  • Field Devices
  • 8257
