User Defined PIN can't take effect
  • User Defined PIN can't take effect
  • sesa145087_brid
    sesa145087_brid
‎2018-09-06 10:25 AM
When using User Defined PIN in the individual, it can’t take effect.
I/NET
Large card number should be used if User defined PIN is needed.
User-defined PINs are supported when all of the following requirements are met:
  • The door controller’s firmware is version 2.30 or later.
  • DIP switch 7 at the door controller is ON or the Card Translation option is enabled in the Door Extension editor
  • The individual is directly assigned a large key/card number (i.e., a key/card translation table is not being used to translate the user’s key/card number).
  • TAC INET
  • 13210
