Use a Xenta 527 on an old I/NET 2000 system
  • Use a Xenta 527 on an old I/NET 2000 system
  • Tom_Poovey
    Tom_Poovey
‎2018-09-07 04:03 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-28 11:31 AM
Can I use the Xenta 527 on an old I/NET 2000 system?
TAC INET
I/NET 2000
Adding a Xenta 527 to an I/NET 2000 network.
Yes you can, provided you set the Xenta 527 up to be compatible with I/NET 2000.
With the Xenta programming cable (P/N 3-781-0128-0) inserted in port "B" of the Xenta 527, go into Windows Hyper-Terminal and make the following changes for the Xenta 527 to operate in an Inet 2000 program.
Please be aware that I/NET 2000 is no longer a supported product and this mode should be used at your own risk.
  • TAC INET
Tags (3)
  • 3141
  • INet 2000 System
  • Xenta 527
