Use Echelon License Diagnostic Utility to check the status of LonMaker credits
  • Use Echelon License Diagnostic Utility to check the status of LonMaker credits
  • Sacco
    Sacco
‎2018-09-07 01:54 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-29 06:40 AM
Echelon now has an easier way to check the status of your LonMaker License. Determine the status of your credits in seconds.
TAC Vista
  • LonMaker 3.1
  • LonMaker 3.2 (Turbo)
  • LNS
Determine corrupted credits/licensing issues without the old method of using the command prompt. This will do the same thing with a click of a button.
The tool will diagnose the license status and give you the solution you need to follow to fix the problem.
  1. Download here: Echelon License Diagnostic Utility
  2. Save or run
  3. Choose LonMaker credits
  4. Copy to clipboard and email to Echelon if corrupted credits are shown.
Screen shot of invalid LonMaker license:
This error occurs if the license file you specified is not located in the application directory. To resolve this, you will need to reboot your PC and log in as a user with Administrative privilege. Next, make sure the files listed below are located in the C:\Windows\LNS Licenses folder.
Note that the "LNS Licenses" folder is a hidden one; therefore, in Windows Explorer, go to Tools - Folder Options..., and in the View tab, select "Show hidden files and folders." Now uncheck the "Hide protected operating system files (Recommended)" option.
  • 3157
