Upgrading Vista (and other modules such as Webstation) may require an upgraded license
  • Upgrading Vista (and other modules such as Webstation) may require an upgraded license
  • SESA150559
    SESA150559
‎2018-09-06 12:52 PM
Depending on the initial version of Vista it may be necessary to order and use the "Upg" licenses when upgrading from an older version of Vista to the current version
  • TAC Vista versions within the same sub range:
    • 5.0.x
    • 5.1.x
License upgrade types
The licenses are limited to the ranges of 5.0.x and 5.1.x. Upgrades within these ranges are free.
Example:
5.0.1 to 5.0.3 is free of charge.
5.0.1 to 5.1.0 needs upgraded licenses. Use the "Upg" license package when ordering.
5.1.0 to 5.1.5 is free of charge.
  • 6982
