Upgraded Vista 3 to Vista 5 and Digital Points can not be changed on OGC graphic page
  • Upgraded Vista 3 to Vista 5 and Digital Points can not be changed on OGC graphic page
  • SESA116857
    SESA116857
‎2018-09-06 02:46 PM
  • Vista 3 system upgraded to Vista 5
  • Digital points
  • OGC Graphics
This behavior has only been seen after a upgrade from Vista 3 when following the recommended upgrade path and does not effect every single digital point.
The inability to control a digital point in an OGC graphic page on Vista 5 Webstation can be fixed by opening the offending graphic page in the graphic editor and then saving it back to the Vista DB.
  • 3093
