Upgrade path from version 1.0 to current version
  • Upgrade path from version 1.0 to current version
‎2021-02-16 12:31 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:22 AM
Upgrade path from version 1.0 to a current version
  • SmartStruxure Building Operation versions 1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7, 1.8, 1.9
  • EcoStruxure Building Operation versions 2.0, 3.0, 3.1, 3.2, 3.3 (limited), 4.0, 5.0, 6.0
Upgrade path from version 1.0 to current - version
Important - The upgrade process is sequential, for example, 1.1 to 1.2 to 1.3 to 1.4 From v1.9, non-sequential upgrades are possible
The primary released versions were, Release Note Dates (approximate)
1.0.0.161
1.1.0.362 Dec 2011
1.2.0.767 July 2012
1.3.0.938 Nov 2012
1.3.0.10100 SP1
1.3.0.20011 SP2
1.4.0.4020 Sept 2013
1.4.1.68-73 Oct 2013
1.5.0.532 July 2014
1.6.0.250 (RC) Dec 2014
1.6.1.5000 Feb 2015
1.6.2.27 Maintenance Release Jun 2016 see TPA-SBO-16-0003
1.7.0.255 (RC) July 2015
1.7.1.89 Oct 2015
1.7.2.29 Maintenance Release Jun 2016 see TPA-SBO-16-0003
1.8.0.244 (RC) Mar 2016
1.8.1.79-87 Jun 2016
1.9.1.95 Apr 2017
1.9.2.45 Maintenance Release Oct 2017  - See release note
1.9.3.24 Maintenance Release April 2018  - See release note
1.9.4.29 Maintenance Release April 2019  - See release note
2.0.1.130 & 135 June 2018 (130(License, WS, Reports Server) 135 - Server (AS, ES, EC)) - See release note
2.0.2.67 Maintenance Release Sep 2018  - See release note
2.0.3.45 Maintenance Release Dec 2018  - See release note
2.0.4.83 Maintenance Release June 2019  - See release note
3.0.1.104 May 2019  - See release note
3.0.2.33 Maintenance Release July 2019  - See release note
3.0.3.11 Maintenance Release Aug 2019  - See release note
3.0.4.43 Maintenance Release Dec 2019  - See release note
3.1.1.312 Dec 2019  - See release note
3.1.2.29 Maintenance Release Mar 2020  - See release note
3.2.1.630 Aug 2020  - See release note
3.2.2.61 Maintenance Release
Nov 2020  - See release note
3.2.3.59 Maintenance Release
Mar 2021  - See release note
3.3.1.59L Limited distribution release Feb 2021 - intended for specific feature compatibility with some hardware or applications - See release note
EBO 2022 (4.0.1.86)
Dec 2021 - This version follows v3.x, and reflects a new naming convention focused on release year for clarity - See release note
EBO 2022 (4.0.2.559 & 562) Maintenance Release
Apr 2022 - WorkStation Hotfix and License Admin 4.0.2.562, others 4.0.2.559, see revised release note
EBO 2022 (4.0.3.176) Maintenance Release
Jul 2022 - See release note
EBO 2023 (5.0.1.86)
Dec 2022 - See release note
EBO 2024 (6.0.1.93)
Mar 2024 - See release note
It is most important to read the Release Notes and System Upgrade Reference Guide for each version you are upgrading to, as there are some special notes that only apply to some installation types.
Click Here for Release Notes
Click Here for Upgrade documentation
The Minimum upgrade path would be as below (See Release Notes for any special instruction)
  • 1.0.0.161
  • 1.1.0.362 See StruxureWare Building Operation v1.0 to v1.1 upgrade issues Appendix A
  • 1.1.0.1225 See Appendix A
  • 1.2.0.767 See Appendix A This version can be avoided by using 1.2.0.1412 if possible
  • 1.2.0.2207 (Hotfix) Available from PSS See also Appendix A
  • 1.3.0.938 See also Appendix A
  • 1.3.0.10100 (SP1) (needed if runtime compatibility is required during upgrade)
  • 1.4.0.4020 or 1.4.1.68 (Only needed if runtime compatibility is required during upgrade) See Upgrading Automation Servers from 1.3 to 1.4
  • 1.5.0.532
  • 1.6.1.5000 See Upgrade to 1.5.0 or 1.6.0 fails
  • 1.7.1.89
  • 1.8.1.87 See Product Announcement 00471 Pre-Upgrade LON Add-On 1.7.1 to 1.8.x
  • 1.9.1.95 Possible to upgrade directly from v1.5, but carefully study the release notes and upgrade instructions
    • Option to 1.9.2.45 Upgrade options more limited with this version, only from v1.7.2, see the release note
    • Option to 1.9.3.24 Upgrade options more limited with this version, only from v1.7.2, see the release note
    • Option to 1.9.4.29 Upgrade options more limited with this version, only from v1.7.2, see the release note
  • 2.0.1.130/135 Possible to upgrade directly from v1.5, but carefully study the release notes and upgrade instructions. NOTE the new License structure for v2.0.
  • 3.0.1.104 Possible to upgrade directly from v1.8, see the table in "System Upgrade Reference Guide" (3.0.1 System Upgrade Overview), but carefully study the release notes and upgrade instructions. NOTE the new Licenses for v3.0.
  • 3.1.1.312 Possible to upgrade directly from v1.8 See Release notes and upgrade documents for full details
  • 3.2.1.630 AS Classic not supported, Win 7 and Win server 2008 not supported
  • 3.3.1.59L Limited distribution release - intended for specific feature compatibility with some hardware or applications, see release note for details. If you do not require the specific features outlined in this Release Notes, it is recommend installing EcoStruxure Building Operation 3.2.x instead
  • EBO 2022 (4.0.1.86 and later) The following protocols, objects, and devices are not supported in EcoStruxure Building Operation 4.0 or higher: I/NET, Sigma, MicroNet, NETWORK 8000 ASD and LCM. A multi-version system supports I/NET, MicroNet, NETWORK 8000 ASD and LCM on automation servers and Sigma on an enterprise server, running an earlier version than 4.0. Report Server/WebReports is not supported in EcoStruxure Building Operation 4.0 or higher. See release notes for details.
  • EBO 2023 (5.0.1.128 and later) New SpaceLogic and Easylogic Controller support, External Storage support for MS SQL, Some support for IPv6, BACnet protocol rev.16, Virtualized Automation Server - Edge Server added,   See release notes for details.
  • EBO 2024 (6.0.1.93 and later) Added New Software Assurnace, Sustainability Pack, EBO Enterprise Server and Enterprise Central for Linux, OPC UA Client Support, Modbus2 Support, Visual Programming for Function Block, XLSX Report, and Touch Room Controller Support. See release notes for details.
Appendix A - Upgrading from Specific 1.x Builds
Upgrade from V1.0.0.XXXX to V1.3 (via V1.1 and V1.2)
  • Upgrade from 1.0.0.XXXX to 1.1.0.1225
  • Upgrade from 1.1.0.1225 to 1.2.0.1412 (Do not use 1.2.0.767)
  • Upgrade from 1.2.0.1412 to 1.3
Upgrade from V1.1.0.XXXX to V1.3 (via V1.2)
  • Upgrade from 1.1.0.XXXX to 1.2.0.1412 (Do not use 1.2.0.767)
Upgrade from V1.2.0.767 to V1.3
  • Apply hotfix 1.2.0.2207
  • Upgrade from 1.2.0.2207 to 1.3
NOTE: These hotfix builds are not available for download from the Extranet site, you will need to contact Product Support and request them
Tags (14)
  • 16917
  • DavidShore19
  • DavidShore20
  • DavidShore21
  • DavidShore22
  • DavidShore23
  • GaryMontague21
  • GaryMontague22
  • HenrikTarpgaard21
  • MahmoudSayed22
  • PeterEdvik22
  • rule
  • rules
  • StephenYang24
94% helpful (15/16)
