Upgrade of Continuum displaying error "C:\program files\continuum\userprofiles\xpress.mnu" unable to locate
  • Upgrade of Continuum displaying error "C:\program files\continuum\userprofiles\xpress.mnu" unable to locate
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:16 PM
Continuum Cyberstation
Upgrade of Continuum software was unable to located a custom menu file. Suspected file was not in specified location.
Once logged into Continuum.
  1. Edit workstation
  2. Select Preferences tab
  3. Select "The File name of the menu"
  4. Browse for location of the Custom *.mnu  OR select default location "C:\program files\continuum\userprofiles\Continuum.mnu"
Note: if the patch on the previous installation was non-standard, then save off a different Continuum.mnu, point all the buttons to the new path, save it and then point all the Cybers to the new Continuum.mnu
  • 4363
