Upgrade IMI Video system to the new Datacard (ID Works) system
  • Upgrade IMI Video system to the new Datacard (ID Works) system
  • Tom_Poovey
    Tom_Poovey
‎2018-09-06 11:52 PM
Last Updated: Administrator DavidFisher Administrator ‎2020-08-10 02:31 PM
When upgrading an IMI Video system to the newer Datacard (ID Works) system, are there any files or utilities needed besides the ID Works software?
TAC INET
  • I/NET Seven
  • IMI Video system
  • Datacard ID Works
Converting the IMI Video Badging system to Datacard system
There are 3 files that you need.
  • Click Convert.zip to download them.
  • Also, INET Application Guide AG-2002-01.pdf has additional information on this process.
When converting the IMI Video Badging system to Datacard system, the first step in the IMI system to begin the convert process is to re-index the database files before attempting to batch export the data. If you have multiple tenants you must perform this procedure for each tenant.
ID Works ODBC String. Type the string as you see it including the case:
UPDATE ACP001 SET FIELD16 = 'C:\Photo\' + cardnumber + '.JPG'
Make sure the case and spaces are just like the above to avoid any problems. Make the path anything you like, but remember the C: string cannot exceed 50 characters.
  • TAC INET
convert.zip
Tags (3)
  • 896
  • Datacard
  • ID Works
