Updating the Loytec NIC driver
  • Updating the Loytec NIC driver
  • Benji
    Benji
‎2018-09-06 02:35 PM
  • NIC852
  • NIC-USB
You can run into trouble upgrading the Loytec NIC driver on a PC where there is already an existing TAC Vista installation. If you do the update like this, you should stay clear.
  1. Stop TAC Vista Server, and if it's running as a service, set it to disabled.
  2. Unplug the NIC-USB or NIC852.
  3. Uninstall the NIC driver.
  4. Delete the folder %ProgramFiles%\Loytec\NIC
  5. Delete the HKLM\SOFTWARE\LOYTEC folder in the registry
  6. Reboot the PC
  7. Install the new Loytec driver
  8. Reboot the PC
  9. Insert the NIC-USB or NIC852
  10. Start TAC Vista server
  • 3569
