Unwanted 'Pan and Zoom' on TGML Graphics when using Webstation
  • Unwanted 'Pan and Zoom' on TGML Graphics when using Webstation
  • DavidChild
    DavidChild
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2019-02-06 02:48 AM
on ‎2019-02-06 02:48 AM
When editing an EBO graphic in Webstation rather than Workstation, there is an inherent feature which allows a user to zoom in and out of the graphic using the mouse scroll. They can also pan around the page by holding down the left mouse button as they move.
In many cases however, this feature is not wanted and makes the graphic more difficult to use.
Image Zoomed Out
Image Zoomed In and Panned Right
Building Operation Webstation
  • Graphics
Pan and Zoom in Webstation are features that are enabled by default in all TGML Graphics
Edit the graphic object and select the top TGML root of the page properties. There is a 'Disable Pan and Zoom' option which by default is set to False.  Setting this option to True and then saving turns off the Pan and Zoom functions for that graphic
Tags (3)
  • DavidChild19
  • DavidKendrick19
  • webstation
84% helpful (5/6)
