Untranslated infinity error when creating object in b3 or i2 device.
  • Untranslated infinity error when creating object in b3 or i2 device.
  • Dave_Shore
    Dave_Shore
  • DavidChild
    DavidChild
  • AbeMeran
    AbeMeran
‎2018-09-11 01:39 PM
  • Building Operation Workstation
  • Infinet i2 Controller
  • BACnet b3 Controller
b3/i2 devices do not support certain characters in their objects name.
For example, creating an analog input using the name AI-1 will cause the error is the BACnet field is left blank, the EBO name AI-1 can be used but a name needs to be specified in the BACnet name field that is consistent with the b3 naming convention such as AI_1.
Tags (2)
  • 17221
  • DavidShore20
34% helpful (1/3)
