Uninstall PCT 2.0
  • Uninstall PCT 2.0
Uninstall PCT 2.0
Admiral StephenYang Admiral
‎2024-05-30 02:02 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:31 AM
How to uninstall PCT 2.0.
Project Configuration Tool.
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
The uninstalling instruction isn't documented.
  1. Launch Hyper-V.
  2. Shut Down PCT VM.
  3. After the VM is shut down, select Delete from the bottom right window.
  4. Select Delete if the confirmation window prompts. It may take some time depending on the VM size.
  5. Go to the VM location selected during the PCT installation
    The default installation path is
    "C:\ProgramData\Schneider Electric EcoStruxure\Building Operation\Project Configuration Tool 2.0"
  6. Right-click on the pct folder then select Delete
    (This action will delete all the data in PCT including projects and servers created)
Labels (2)
  • Project Configuration Tool
  • StephenYang24
75% helpful (3/4)
