Unbound signals in Webstation appear as offline.
  • Unbound signals in Webstation appear as offline.
‎2018-09-06 02:23 PM
TAC Vista Webstation 5.1.4 and prior
In Vista Workstation, unbound signals are ignored; but in Webstation, and unbound signal is treated as offline.  This may result in a red X across the entire component if any binding is unbound.  This is an inconsistency across the two platforms.
  1. Make sure all signals are bound.  Even if it's a binding that is not used for any display purpose (like a multi-bind .[OBJECT] binding for example).
  2. Any signals that are unbound and unnecessary should be removed from components.
  • 4111
