Unable to view b3 array element value
  • Unable to view b3 array element value
‎2018-09-10 12:58 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:58 AM
In EBO there is no build in way to view b3 array element value.
In Continuum there is a command line that allows printing array elements by specifying the array index.
  • Building Operation ASP, ASB, AS
  • b3 BACnet devices
  • Infinet i2 device
The Infinet i2 device object array values can be viewed as WebHelp.
This option is not available with b3 BACnet controllers.
A workaround is to use a Script program to expose the array element value.
See Sample Script Program to expose b3 array element value.
Tags (2)
  • 18896
  • DavidShore21
