Unable to view TGML graphics in webstation. Get a blank screen with an error message from java console.
  • Unable to view TGML graphics in webstation. Get a blank screen with an error message from java console.
  • sesa177673
    sesa177673
‎2018-09-06 01:49 PM
Get the following error message when viewing a TGML graphic in Webstation:
Java-plugin 1.6.0_20
Använder JRE-version 1.6.0_20-b02 Java HotSpot(TM) Client VM
Användarens hemkatalog = C:\Documents and Settings\Administrator
c:   töm systemfönster
f:   slutför objekt i slutföringskö
g:   skräpinsamling
h:   visa det här hjälpmeddelandet
l:   dumpa classloader-lista
m:   skriv ut minnesförbrukning
o:   utlösarloggning
q:   dölj konsol
r:   ladda policykonfiguration på nytt
s:   dumpa system- och distributionsegenskaper
t:   dumpa trådlista
v:   dumpa trådstack
x:   töm classloader-cache
0-5: ange spårningsnivån till
PostSender: Failed to create json object: request sent is includeHidden:true, tgmlId:, requestId:3211, path:objectId=715325441&, command:GetObject, includeViewType:true, includeAggregated:0,
java.lang.NullPointerException
            at java.lang.String.indexOf(Unknown Source)
            at SE.Graphics.communication.TgmlGetter.checkFileIfExistsAndNotModified(TgmlGetter.java:279)
            at SE.Graphics.communication.TgmlGetter.readTgmlObject(TgmlGetter.java:374)
            at SE.Graphics.viewer.TgmlJComponent.fetchTgmlStr(TgmlJComponent.java:127)
            at SE.Graphics.viewer.TgmlJComponent.loadTgmlDocument(TgmlJComponent.java:108)
            at SE.Graphics.viewer.TgmlApplet.init(TgmlApplet.java:104)
            at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
            at java.lang.Thread.run(Unknown Source)
Undantag: java.lang.NullPointerException
or
Detected from bootclasspath: C:\PROGRA~1\Java\jre7\lib\deploy.jar
Couldn't get Int parameter debuggingPort null returning 80
Couldn't get Int parameter minPollInterval null returning 500
@TgmlApplet#init object path is: objectId=1709965313&, server path: https://system.evalvomo.fi/webstation/active.tgml?
key 0: ASP.NET_SessionId
value 0: v30z342d1nj34zwcjm1a3agu
Added cookie to result: ASP.NET_SessionId=v30z342d1nj34zwcjm1a3agu
Proxy list:[DIRECT]
proxy hosttype: DIRECT
No Proxy for this hosttype - clearing proxy settings.
executePost failed: HTTP/1.1 404 Not Found
PostSender: Failed to create json object: request sent is includeHidden:true, tgmlId:, requestId:1734, path:objectId=1709965313&, command:GetObject, includeViewType
TAC Vista 5.1.X
Windows 2003 server
The .tgml extension has for some reason not been registered in Internet Information Services.
  1. Confirm that the error is as described above
  2. Register the TGML extension
    1. Go to the Start Menu and select Run.
    2. Type INETMGR and click on OK - this will open the Internet Information Services (IIS) console.
    3. Locate the virtual directory Webstation (\Web Sites\Default web site\Webstation) and right click on it.
    4. Select Properties
    5. Click on the Configuration button.
    6. Look for the .tgml extension in the dialogue Application Configuration that opens up, under the tab Mappings.
    7. If the problem is as reported, .tgml should not appear in the list. Click on Add and add the .tgml extension.
    8. Click on OK on all the open dialogues and then restart IIS.
    9. Click on Edit  and verify the checkbox "Verify that file exists" is not checked.
  3. Restart webstation and confirm the TGML are now working.
  • 5294
This is a heading
