Unable to use the "Put" command from the DB Admin tab of the Admin Tool in Workplace Pro. Cannot select file buttons.
  • Unable to use the "Put" command from the DB Admin tab of the Admin Tool in Workplace Pro. Cannot select file buttons.
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:44 PM
  • Workplace Pro
  • UNC series
UNC must be in idle.
The "Put" command can only be used to import a database to an "idle" UNC. To idle a running UNC, uncheck it's "Auto Start" box and reboot.
  • TAC IA Series
  • 3168
