Unable to set up Report - Chart object in Vista
  • Unable to set up Report - Chart object in Vista
  • LeeCravens
    LeeCravens
‎2018-09-10 11:06 PM
Although a new Report - Chart object can be created in Vista, there is no documentation that explains how to make it work or what it does
TAC Vista 4.2.0 Workstation and newer
The Report - Chart function was removed in Vista 4.2.0 although it can still be created up through Vista 5.1.8
Although it was possible to create a new Report - Chart object in Vista 4.2.0 - Vista 5.1.8, the objects were not functional. The Report - Chart object was replaced with the Trend Chart object and instructions on how to set up Trend Chart objects can be found in the Vista documentation.
  • 11908
