Unable to set the nciDischAirMax higher than 104°F in the Xenta 104-A plug-in
  • Unable to set the nciDischAirMax higher than 104°F in the Xenta 104-A plug-in
  • Anonymous user
‎2018-09-10 03:43 AM
The Xenta 104-A plug-in limits the temperature value input between 32°F and 104°F.
Xenta 104-A Plug-In
Lonmaker 3.1 or Lonmaker 3.2
NL220
In Vista follow these steps:
  1. Navigate to the Xenta 104-A controller.
  2. Browse down to the 8030 function block and find the nciDischAirMax SCPT.
  3. Type in the designed high discharge air temp value.
  • 6478
