Unable to order parts that were previously available before discontinuation of low volume parts
  • Unable to order parts that were previously available before discontinuation of low volume parts
‎2018-09-11 01:40 PM
Last Updated: Crewman ContentModerator ‎2025-10-15 03:40 AM
Trying to order a controller part number that has been discontinued due to low volume sales / duplicate part numbers.
Andover Continuum
  • Continuum IP level Controllers
  • NetController II Series
  • bCX1 Series
  • ACX Series
Discontinuation of duplicate and low volume parts has removed a number of previously existing part numbers from the Continuum catalog. These parts are still available but will need to be ordered as a base unit and then upgraded through Repairs.
The IP level controllers were part of a roll up of the product numbers where low volume part numbers were discontinued. These parts can still be obtained but will need to be chosen from the list of available parts and then get an upgrade through Repairs to add the additional features that may be required. See Active Network Level Controller Part Numbers, and Discontinuance of Low Volume Part Number Configura... on this which includes the currently available part numbers.
To order a BCX1-CR-127-SA part which is no longer available, you will need to order the base unit BCX1-CR-127 and then have Repairs add the -SA (SNMP) option to that controller.
Note: for further Continuum parts that have been discontinued see What Continuum products have been discontinued?.
  • 17303
