Unable to open a time chart via TGML graphic in webstation.
  • Unable to open a time chart via TGML graphic in webstation.
‎2018-09-10 04:56 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:58 AM
Unable to open a time chart via TGML graphic in webstation. The same graphic works in workstation.
TAC Vista 5.1.X - workstation & Webstation
TGML Editor 1.1.X
Binding to the PV value of a time chart isn't the correct way to do this, but workstation is unable to display a dialogue for an object that has multiple properties and so displays the complete time chart.
A link should be used that is linked to the time chart object
Attached is a TGML component adapted from the standard analogue clock component that explains how to do this. The binding should be bound to -your time chart-.PV and the link should be linked to the time chart object.
Time_Chart_Link.tgml
Time_Chart_ Link.zip
  • 6634
