Unable to log in to Vista workstation.
  • Unable to log in to Vista workstation.
  • sesa177673
    sesa177673
‎2018-09-06 03:54 PM
Unable to log in to Vista workstation. Get error message "Failed to init session: Class not registered".
Vista 4.XX
This normally occurs after having downgraded Vista. The problem is that a number of files are stored in the C:\Program Files\Common Files\TAC Shared folder and a version compatibility problem occurs.
  1. Uninstall Vista
  2. Locate the C:\Program Files\Common Files\TAC Shared folder
  3. Delete all the files in this folder
  4. Re-install Vista.
  • 7637
