Unable to install I/NET Seven. Error "Unable to open, File is corrupt"
  • Unable to install I/NET Seven. Error "Unable to open, File is corrupt"
  • Chris_Asbury
    Chris_Asbury
‎2018-09-10 02:01 AM
Unable to install I/NET Seven after downloading software from Buildings Business Extranet. Gets error "unable to open, file is corrupt" when using WINzip
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows Server 2003
  • WinZip
  • Inet 2.30 or below
  • WinRAR
Software was created in a number of parts which all parts needed to be downloaded before unpacking was attempted.
WinZip is not a valid software to unpack the Inet install files downloaded from the Buildings Business Extranet. (now ecobuildings)
  1. Downloading all parts of the I/NET software from the Buildings Business Extranet
  2. Make sure all files are in the same folder.
  3. You will need to use WinRAR to unzip the files
    Download from here http://filehippo.com/download_winrar_32/
  4. You must unzip the files before trying to run the install, if you open part 1 of the files this will automatically unzip all parts of the software, once all files have been unzips the install will work
NOTE: This was an issue with Inet software versions 2.30 and below, all new version can be downloaded and unzipped without issue from the ecobuildings website.
  • TAC INET
  • 6161
