Unable to create new OGC graphic pages in Xbuilder 5.0.2 or later because the edit option has been grayed out
  • Unable to create new OGC graphic pages in Xbuilder 5.0.2 or later because the edit option has been grayed out
  • SESA116857
    SESA116857
‎2018-09-06 02:43 PM
Unable to create new OGC graphic pages in Xbuilder 5.0.2 or later.  The edit option has been grayed out and I cannot open the OGC graphic editor.
  • XBuilder
  • TGML Graphics Editor
  • Vista
In Xbuilder 5.0.2 the system was changed to support UTF-8 character encoding. Since OGC Graphics pages cannot support this change all new graphic pages added to XBuilder will be forced to be TGML pages which support the UTF-8 character encoding.
OGC graphics created in earlier versions of XBuilder will still display properly when those projects are upgraded to newer versions of XBuilder but they can no longer be edited. If changes need to be made to these files you can follow one of the two options listed below:
#1. In order to make changes to these graphics the files must first be upgraded to TGML graphics. This is done by opening the OGC graphics with the TGML editor and the graphics will be automatically updated.
#2. It is possible for 2 versions of XBuilder to reside on one PC. You can download the 5.0.2 version of XBuilder and use this version of the tool to make the necessary changes. Once the changes are made you will save the project and open the edited project in the newer version of XBuilder.
  • 3218
