Unable to backup an R2 UNC-520 database, receive error "java.net.ConnectException: Connection refused: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at ja...
  • Unable to backup an R2 UNC-520 database, receive error "java.net.ConnectException: Connection refused: connect at java.net.Pl...
  • SESA113595
    SESA113595
‎2018-09-10 12:17 AM
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.(Unknown Source)
at tridium.nre.drivers.SocketDriver$TcpSocketFactory.createSocket(SocketDriver.java:690)
at tridium.nre.drivers.SocketDriver.create(SocketDriver.java:216)
at tridium.nre.drivers.SocketDriver$ConnectThread.run(SocketDriver.java:510)"
I/A Series R2 UNC-520
I/A Series R2 WorkPlace Pro,  error reported in build r2.301.529
The WorkPlace Pro cannot connect to the UNC-520 at the given IP address.
The error message stems from a bug in the Sun java, "The Socket constructor does not give an Exception on an unknown IP address. It just hangs."
 http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=4232651
Verify that the UNC is capable of communicating at the IP address specified. For example, if the UNC is rebooting constantly, it will not be able to communicate.
  • TAC IA Series
  • 5669
