Unable to access to JACE-645 via its Ethernet Port
  • Unable to access to JACE-645 via its Ethernet Port
Admiral RyanSuar Admiral
‎2019-10-03 08:00 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:20 AM
Unable to access to JACE-645 via its Ethernet Port. The following is seen when connected to the JACE's Serial Shell.
TAC I/A Series
JACE-645 (TRD-T-645)
The boot sector of the nand flash has become corrupt and/or the nand flash chip may have failed.
The unit cannot be recovered in the field. The options are:
  1. An attempt can be made to re-image the unit but this may not be always successful. Contact Product Support for further details.
  2. Replace the unit. Refer to PA-00502 - End of Commercialization for JACE 600 and JACE 700 for replacement options.
  • TAC IA Series
  • RyanSuar19
